It is currently Sun Jun 22, 2025 6:35 am
PostPosted: Fri Feb 17, 2006 1:40 pm
Once again.....took my eyes off the work and ended up messing up!
So here's what happened:
I was shapping the neck (with a Madagascar RW fingerboard and Maple Binding) when I got distracted and looked away and "voila"....sanded through the binding all the way to the fingerboard right at the end where it meets the nut! About 1/4 inch of binding is missing
Any suggestions?
I was about all done too
Start a new one is always a good suggestion but I rather fix this one first
PostPosted: Fri Feb 17, 2006 2:00 pm
I am *not* a repair expert (well, nor a building expert for that matter!
), but what about this...
clamp to the fingerboard a small block of wood with a straigt edge such
that it would work as a fence of sorts for a laminate trimmer or dremel
with a _Binding/Binding_Router_Guide.html">binding router guide. The
fence would be such that it will allow you to cut a new rabbet at an angle
that will give you the width of binding you need at the nut and will
"blend" into the existing binding over, say, six inches. Set a new piece of
maple on that rabbet and plane or scrape it flush with the existing
binding.
If you're a better jointer than me, with maple I imagine the joint could be
hidden pretty well.
Tell me if I'm making no sense at all. Or if it's just a dumb idea, which is
also a distinct possibility
Good luck.ecklesweb38765.9175578704
PostPosted: Fri Feb 17, 2006 2:06 pm
First name: R
Last Name: Coates
City: Selma
Never give up a chance to try a repair. I'd say patch it or replace it. The question is though did you get into the neck wood too deep also? That might be a tough one.
I'm not a repair guy so wait for one of the repair heavy weights to chime in. Might help to see it.
Good luck
PostPosted: Fri Feb 17, 2006 2:16 pm
I think that if you did not cut trough to the neck, it is salvageable, maybe by applying heat, scrape it off, make a new binding piece, glue up and voila! bUT WAIT FOR THE PROS!!!!
PostPosted: Fri Feb 17, 2006 3:49 pm
Heat the binding. remove it and replace. You will be happier later down the road
PostPosted: Fri Feb 17, 2006 3:54 pm
Thanks Michael me thinks i didn't do so bad in your absence han ? Waddaya say coach Michael ?
PostPosted: Fri Feb 17, 2006 4:02 pm
I don't think I would try to patch it. I agree
with the others,replace the binding.
PostPosted: Sat Feb 18, 2006 1:48 am
[QUOTE=Serge Poirier] Thanks Michael me thinks i didn't do so bad in your absence han ? Waddaya say coach Michael ? [/QUOTE]
spot on Serge
